AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Tip of leader is lighter than the rest of the leader.
2 REPLIES 2
mbaezGWFMJ
317 Views, 2 Replies
I have a leader with a loop and for some reason the tip (the loop) shows up much lighter than the rest of the leader. I cannot figure out what I did or am doing wrong. I circled the loop in yellow in this picture. Can someone please help me.
2 REPLIES 2
pendean
in reply to: mbaezGWFMJ
Edit the block manually (copy then explode one of those leaders to find out what it is called), set the block objects' properties to be BYBLOCK.
mbaezGWFMJ
in reply to: pendean
That worked! Thank you so much!
