SprinkCAD pipe length
I am fire sprinkler designer using SprinkCAD and I am trying to figure out how to show cut lengths and center to center lengths of pipe on same drawing so they do not overlap. Is there any setting that will automatically move cut pipe length bellow center-to-center length? or do I have to move every single one manually
Thank you
pendean
Community Legend
Community Legend
jamieq
I know it's a long time since you asked this, but I happened to find it and also use SprinkCAD. This is definitely a SprinkCAD question, although it relates to AutoCAD objects. The only way to move all of cut or c-c lengths at one time would be to edit the "CUTPIPE" block, either in the block editor (BEDIT) or edit block in place (REFEDIT). In it there are two attributes, once called "CCPIPE" and the other "CUTPIPE", self explanatory. You could move them one over the other, or side by side, whatever you choose. Then save the block, and use the ATTSYNC command to update the block attributes. Any block that's had the sizes moved already will have them move back. But they will now be in the places you put them in the edited block. Outside of this, or you will have to move each length manually.
