AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
SP1 for ADT2004 modules of ABS
6 REPLIES 6
239 Views, 6 Replies
I have tried the SP1 update for the ADT components of ABS2004, refuses to
install. Is there a separate one for ABS ?
-Raj
6 REPLIES 6
Hi Raj -
We have not yet released an SP1 for Autodesk Building Systems. The ADT
service pack is for ADT only.
I hope this helps!
"Raj" wrote in message
news:628263B4CAA053EA7010A1847A172509@in.WebX.maYIadrTaRb...
> -Raj
Peter, Are there any ill effects if I have both ADT2004 & ABS2004 on the
same machine, and I install SP1 on my ADT2004?
-jim
The only illnes you could expect is a full hard disk. Oh... wait. I'm the
only one working on laptop here... :o(
"Jim" wrote in message
news:740D61204BEC6CBE22BEA4AFAEF9734C@in.WebX.maYIadrTaRb...
> Thanks,
> -jim
I've been wondering the same - I presume the service pack updates files in
the shared directory that is used by both ADT 2004 & ABS 2004, but won't be
updating the files in the application's directories - thereby semi-patching
ABS 2004 as well?
Jon Smith
COINS
> Thanks,
> -jim
Hi Jim -
No ill effects. We will roll-up both ADT and ACAD service packs when we
issue our own.
Everyone - keep those error reports coming in!
> Thanks,
> -jim
Uh Oh!
Turns out there is a minor problem. Apparently, there is a bug that
requires that the install order of side-by-side ADT/ABS be ADT first, then
ABS. Well, installing the service pack changes the install order to ABS
first.
To fix this - go into the control panel ->Add/Remove Programs -> Autodesk
Building Systems -> Change -> Reinstall or Repair Autodesk Building Systems
2004 and continue the wizard. There is no need to reinstall any of the
applications.
My apologies...
"Peter Terwilliger [Autodesk]" wrote in
message news:C8F6F15A2E6390CDF756AFC4CE1E074C@in.WebX.maYIadrTaRb...
> Hi Jim -
> issue our own.
> > Thanks,
> > -jim
”Boost
