AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Read Only Locked Tool Palette - Again
2 REPLIES 2
npsconsultingllc
188 Views, 2 Replies
Why is it that AutoCAD Arch/MEP consistently makes the tool palette "Read-Only" and is there any actual way to fix this when it happens? All of the available info online suggests the same fixes that don't work and eventually the final (and only) fix is to re-build the tool palette, which takes hours upon hours.
This has been an ongoing issue for YEARS.
Are there any actual fixes to this issue?
2 REPLIES 2
pendean
in reply to: npsconsultingllc
AND
npsconsultingllc
in reply to: pendean
Yes these are the same fixes that don’t work, and notice that it eventually suggests “re-building the palette”.
If the only solution that works is to spend hours rebuilding the entire thing then it’s not a solution at all.
