AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Quick Properties not displaying
4 REPLIES 4
jaume.alvado
741 Views, 4 Replies
I installed AutoCAD 2024 a month ago but since last week I can't display the Quick Properties when I select an object, line or whatever. Qpmode is on 1. I switched off and on again my CAD but still not working. Could someone help please?
4 REPLIES 4
Eng-Seng
in reply to: jaume.alvado
are you using dual monitors?
you might want to check the value of QPLOCATION.
set it to 0 so that the QP palette appears near the cursor.
regards,
Eng Seng.Chua
AutoCAD Toolsets
jaume.alvado
in reply to: Eng-Seng
Thanks! It works!
John_Figueroa
It didint work for me, still not showing up
pendean
in reply to: John_Figueroa
Not enough information, sorry. Did you match the settings in the two screenshots in the first post as well as the tagged solution post?
