Problem with extension zoom in wireframe 2D (flexible ducts)
marco.defina
Message 1 of 13
marco.defina
i found a bizarre problem.
If i click on extension zoom when i am in Conceptual or xRay view i see the entire drawing.
If i click on extension zoom when i am in Wireframe 2D i see the drawing very small. It seems as i have a object in the space but it's not so.
So i tried to delete all the flexible ducts, i click on extension zoom when i am in Wireframe 2D and work fine Smiley Mad
There is a problem with flexible ducts.
Attached the video.
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
Replies (12)
Message 2 of 13
VitalyF
Maybe there are objects that are very far relative to the main model
1.Try the command "Select" with the option "All"
2.Then select your model using the window with pressed "Shift" key and press "Enter"
3. Type "Delete" with the option "p", "Enter"
pre-test with a simple example!
EraseObjects.avi
Vitaly
Message 3 of 13
marco.defina
This is the first thing i tried,but it's not this the problem. In conceptual view there is not this problem.
See the video...It's only a problem of visualization in wireframe 2d of the flexible ducts.
Message 4 of 13
VitalyF
when removing you used a top view and 2d Wireframe?
... an example would be very useful )
Message 5 of 13
marco.defina
yes there is nothing in the space, only in wireframe in 3d view, in top view no problemszoom.gif
Message 6 of 13
VitalyF
You are using a custom mvblocks or mvparts?
They also can be with foreign objects... most likely it 3d objects - blocks
Message 7 of 13
marco.defina
yes, but the problem are flexible ducts (standard parts of catalog)
Attached files with only flexible ducts.
Message 8 of 13
VitalyF
With the rotation of all right, the problem is elsewhere, optionally in the template
PS
The model is very far from the origin! Try to move it nearer to the origin
RotateFlexDuct.avi
Message 9 of 13
marco.defina
only with the zoom extension...i don't knowSmiley Frustrated
Message 10 of 13
VitalyF
LineToOrigin.avi
Message 11 of 13
marco.defina
how i can resolve? Need i to move the drawing to the origin? I will be crazy with the xref where i have the entire 2D section.
Message 12 of 13
VitalyF
Smiley Happy
I'm sorry, perhaps better move the origin to the model...
Message 13 of 13
marco.defina
OK ThanksSmiley Happy
