Placing Multiple Blocks
Message 1 of 1
I'm new to this forum and lispertines, but I thought I'd give it a try. I'm working with MEP 2018 and looking for a lisp that will work in the following way:
-Type “rec” in command --> prompts to set scale
-Set Scale
-Left click --> inserts predetermined block up to closest line or polyline and perpendicular to that line
-Loop (should be able to left click over and over again placing the same block at the same scale, but up to and perpendicular to the new line)
-Ctrl Z --> undo last insertion
-ESC or spacebar --> ends lispertine
I attached a picture showing blocks placed and the cursor shows where the next block would be inserted. I'm not sure if this is possible. Any info would be appreciated.
Mo
Replies (0)
