Pipe Single Line Graphics Styles - Transitions
For a little bit of context, I will describe how I appreciate some functions of the StyleManager.
Under Plumbing-Systems you can define how single line pipe fittings appear as a default, this is a great functionality. You can even turn off the appearance of a fitting if you wish. Unfortunately, the size is predefined by the annotative scale and you can not scale them up or down.
Under Piping-Systems, you can define how the single line styles are applied with the Pipe Single Line Graphics Styles and Pipe Rise Drop Styles. Both Styles can use an annotative scale and an override scale. This is a great functionality.
However, I come to the impasse of being unable to change either the scale or appearance of the concentric pipe transitions for Piping-Systems. The only option I have found for the single line display is to simply turn them off. This wouldn't be an issue of the piping visually connected to each other, instead, it leaves a gap where the transition was and the piping does not appear to be connected to each other.
The hope is that functionality can be added to either: change the scale of the transitions or change the appearance. ie not just turn them off but change like other options described above. Possibly, add a Pipe connection type Under Single-Line_Graphics that is just "Transitions" leave the Aecb_Standard_Single_line but allow it to scale annotatively and have an override scale.
