Pipe Schedule
Pipe Schedule
mcawson
Message 1 of 9
Pipe Schedule
mcawson
Can someone tell me how to easily create a simple pipe schedule?  I'm struggling with it.  If I take a new drawing and just draw 20 feet of 2" pipe and tag it, how do I create a schedule that shows that pipe on it, including the length, size, and material type?  When I try it I just get all blanks in my schedule and a quantity of "1".  Thanks.
Replies (8)
Message 2 of 9
mcawson
Screen shot attached showing what I get.  Missing all of the info on the pipes.  How do I get the schedule to show that information.  Doesn't seem like it should be that difficult.
Message 3 of 9
andkal
Command BOMTABLES
• www.autolisps.blogspot.com - Productivity plugins for Autocad and Autocad MEP
• Autodesk AppStore
Message 4 of 9
mcawson
Then what?
Message 5 of 9
andkal
Then you select pipes and fittings, accept with enter and pick point where autocad is supposed to paste the schedule
• Autodesk AppStore
Message 6 of 9
mcawson
Man that was easy.  I was trying to use the "schedules" in the ribbon...didn't work.  BOMTABLES works well.  Thanks!
Message 7 of 9
jlimREL7Z
Hey guys,
I havent done any customization in the autocad MEP program.  I just use it as is.
When I try BOMTABLES is came out to be like this.
i did a simple system to test came out like this
And when i use the tag & schedule. came out to be all ????
Message 8 of 9
The pipe objects don't have the attributes associated yet.
Right click the Schedule Table...
select "Add all Property Sets..."
Now select a pipe, and it will have all the necessary schedule fields (and lots more)  available in the property window.
Message 9 of 9
jlimREL7Z
Thank you will try this out.
