Object not rendering properly.
This valve is not rendering properly.  I have tried other valves and it does the same thing.  I am using the NVIDIA Quadro 2000 graphics card recommennded from Autodesk.  The computer specs are at the below the picture.Valve not rendering completely.pngwaylon cpu specs.PNG
Alfred.NESWADBA
if it's only "this valve" while all the other objects look good then it might be a defect with this object, so you can try to run command _AUDIT (to see if there are any database-internal issues), or try to copy & paste the valve into a new drawing, just to see if it's working there, if yes the copy & paste it back to your original drawing (as long as it's not a blockreference that will also cleanup some internals).
You can also try to copy & paste the complete modelspace content into a new drawing.
If nothing helps, can you upload a drawing so we can try to reproduce the rendering issue on our systems?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
I have tried all the suggestions that were mentioned and nothing worked. Attached is the file, maybe you can figure out what is going on. I was thinking that maybe the library with all the parts could be damaged, and need to be reinstalled? It would be great if you could try to reproduce the rendering issue on your systems to figure out the issue, Thank you.
Timothy E. Bender
IT Support Specialist II
Northwest Texas SBDC Network
Texas Tech University
2579 S. Loop 289, Suite 210
Lubbock, TX 79423
Phone: (806)745-3973
Fax: (806)745-6207
Alfred.NESWADBA
Sorry, no file attached..
- alfred -
Alfred NESWADBA
Attached is the DWG file.
Alfred.NESWADBA
opened your drawing, that's what I see (using AutoCAD 2016 on Win 8.1, nVidia GTX 780M, driver release 344.65).
May be another one can see your issues?
- alfred -
Alfred NESWADBA
