Multi-View Block def with a Mask block worked in the past.
mdhutchinson
Advisor Advisor
Message 1 of 1
mdhutchinson
Ran into something here we've faced only a couple times before... but have never solved it.
We have a Multi-View block used for multidiscipline room tags. It has a nested Masking Block. Where the Xreffed is pulled into, the mask is showing up solid.  But into a new drawing it displays as it should.
Of course we are doing edit Object Display and letting the XRef control the display... which has always worked before.
Any ideas why this might be happening?
Replies (0)
