AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
multi tag insert
3 REPLIES 3
pierre.dupuis
355 Views, 3 Replies
multi tag insert
is there a way to put several tags when inserting a device from a tool palette, see the attached file
Labels (1)
3 REPLIES 3
pendean
in reply to: pierre.dupuis
Explain please.
I would like to have a tag for the ID, a tag for the circuit, and a tag for the switch, inserted at the same time and not manually
pendean
@pierre.dupuis You will need to create a custom block with all three in them to use instead.
