Layer Standard / Key Override
I'm kinda new to .net. Can someone give me an example of setting a layerkey override  I have found a couple of layer key examples. They are old enough I can't get them to work in ACA 2015.
Thanks in advance
Matthew
smbrennan
You may find better replies by posting in the AutoCAD Customization forum. There's a sub forum specifically for .NET.
http://forums.autodesk.com/t5/net/bd-p/152
Shawn B.
To help improve Autodesk Products, please Click Here to Vote for ideas and submit your own.
Keith.Brown
Any previous example that you find should work in the current version.  They have not changed anything specific about the AutoCAD Architecture or AutoCAD MEP API in recent releases.  They did however make a general change a few years ago when they added the core console.
Just make sure you are referencing the following DLL's and you should be ok.
accoremgd.dll
acdbmgd.dll
acmgd.dll
Those are the AutoCAD references that changed.  The AEC and AECB references will stay the same.  You might have to manipulate a couple of namespaces in order to get your code to work with the new dlls but as i mentioned before the actual code itself has not changed.
I'm not quite sure how to get that done.  I understand what you are saying.  Here is where I'm comming from.
I found this peice of VBA code for an older version of AutoCAD.
http://forums.autodesk.com/t5/autodesk-architectural-desktop/help-with-my-adt-generate-layers-from-l...
I don't know how to convert it to .net for use in a 2015 version of AutoCAD. I'm also not quite sure how to make it work in my particular setup.  A few comments would help in the code but i'm sure it is going to take some time playing with it.
This is the section I would like to ba able to duplicate.
'set Layer Standard Wildcards
With LayKeyStyle.OverrideSettings
.Item("Discipline").Value = "?"
.Item("Status").Value = "-?"
.Item("Component").Value = "-????"
.Item("Description").Value = "-*"
End With
Thank you
Matthew
