- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I type JOIN, instead of the lines I have selected becoming a single polyline like I have done hundreds of times in the past, I get a prompt asking to Select source object, which then does not join my lines together. I then have to use PEDIT to select Multiple lines, JOIN, Enter fuzz distance, and hit Enter.
My question is : why does JOIN no longer work? All I can think of is something to do with the profile I'm using as I was fiddling with it and I'm not sure if I've changed a variable or system setting or something that messed up the way JOIN works.
I'm using Autocad MEP 2022
@scott.mcgowanBRJVK
Topic Title has been changed for better findability by @joaquim.moral Original Post:
JOIN command doesn't behave like it used to
Link copied
