Hi everyone ,
When i open autocad file in mep , i cant find correct scale between autocad file and mep blocks(wc) , please find the attaced , i think the file is meter reference but mep is mm reference , i changed and try the varisoin about scale but i can not solve , are u see anytime look like this problem. i am so bad about that i can not do anythink its really bad situation .
Thanks a lot.
Solved by christophe.legrand. Go to Solution.
You have a wrong scale.
You put units of your drawing in MM, but it have been drawn in Meter.
You need to adjust correctly Scale unit according the scale you draw.
Put your drawing Unit in Meter.
Delete your WC and purge Mep object.
Now, when you add your wc it's OK.
WKR
I read Your answer but It doesn't work. I'll appreciate if you can be more specific with the steps to correct the issue. I have the same problem and when I changed the units to meters and rescale and I tried to add a conduit and still the conduit was several times bigger than the actual drawing.
So maybe I didn't understood your answer and how to adapt the mep blocks scle to the drawing scale.
Change the scale but don't rescale object (the last option in the dialbox, in my case).
