AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
EXPORTtoautocad command
1 REPLY 1
m_aljweijati
198 Views, 1 Reply
Hi All,
I want to open an ifc file on inventor, so i opened the file on autocad mep, i made "save as" for my drawing, i also did the "bind" command for all refrences, then i tried the commant "exporttoaucad" but the problem is that not all the solid blocks are exist in the new exported drawing, any idea why is that happening?
I used the steps in this page but with mep software.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-convert-IFC...
1 REPLY 1
pendean
in reply to: m_aljweijati
INVENOR is not an AUTOCAD productline: did you meant to type AUTODESK INVENTOR?
You also linked to a page that is about converting an IFC to a STEP file.... aka not what you appear to be needing?
FYI you have to INSERT then EXPLODE all of your references, binding them alone is never going to export as an IFC either. perhaps your missing content was in those "bind" files?
