As shown in attachment ..... DUCT and pipe ICON disappeared from tool bar
how can i restore it ?
Hi mech,
Did you by chance accidently start AutoCAD MEP in AutoCAD mode only? You can check your profile and see what profile you are in. This usually happens when installing the software you also install the AutoCAD icon to the desktop and accidently start the software with that icon instead.
You can verify by going into options and looking to see what profile is active. Also make sure that your shortcut that you are using to start the software does not set the profile to one you do not want and instead sets it to AutoCAD MEP.
Maybe these will help. Links to check your current profile and also to add to your shortcuts.
Working with Profiles
Starting AutoCAD with different profiles
