Duct default label/tag position
I was searching the forums and couldn't find any solution to this.
Is there any way when adding/drawing duct, to display the label or tag automatically at the bottom left corner of the duct.
I know I can offset the label manually, but my labels show the duct lengths which means I have label on every piece of duct so it would require too much time.
I've tried to use Label style offset but with no results.
I've seen it done, please check the link below. This guy draws a duct and get duct length(bottom left corner) and duct size(middle of the duct) automatically -> https://www.youtube.com/watch?v=aho-AfDHPYU
Probably using tags is better starting point here, but I don't know if it is possible to automatically add tag when duct is created/drawn.
Hopefully someone can come up with solution
Thank you in advance!
