Customizing elbow radius
I am using tray that has 24" radius on elbows.  I am having trouble customizing elbow radius's.  Is MEP capable of having custom elbow radius's?
Brian
andkal
You can add your own sizes of radius in Autocad MEPs Content builder
• www.autolisps.blogspot.com - Productivity plugins for Autocad and Autocad MEP
• Autodesk AppStore
How? Is there a place in content builder to update a radius of tray? Can you attach a procedure to change the radius of tray?
Brian
andkal
1) Right click on cabeltrayfitting you want to edit, select "Edit in Content Builder"
2) Under "Size Parameters" section you will find dimensions that define the fitting. You can edit them by rightclicking on it and chosing "edit". You will be taken to Size Parameters dialog window where you can add new sizes, edit existing ones, define whether they have to be calculated or predefined, set their visibility in Object Properties palette etc.
• Autodesk AppStore
Thank you! Can you show me the sequence to set up tray radius before I draw the tray on the drawings?
When I use the editor, I t looks like the units are metric. Is that correct?
Brian Lee
