create junction box between conduit and cable tray
jtm2020hyo
jtm2020hyo
exist any way to insert automatically a junction box (if possible condulet or custom junction box) between conduit EMT and Cable Tray?
JianStewart
I am not very sure your requirements, but there might be few options to meet the similar requirements:
  1. You may create a special Mvpart which has the conduit and cable tray connectors, when you need to connect the cable tray and conduit, you may insert this Mvpart to connect them;
  2. Because actually cable tray and conduit are two different systems, you may create a special fitting like a tee which includes two cable tray connectors and one conduit, then enter the Style Manager and conduit/cable tray routing preference, set this special fitting as a regular used fittings. After that, when you draw this system, you should see this fitting under the necessary senarios.
Hope this helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Stewart Li
Senior QA of AutoCAD
jtm2020hyo
Hope this helps.
I found an image about I was searching for.
... I just have a last request, is it possible for a video to check how should I start? I am very new to AMEP.
PD: in the image, the condulet device works like junction box of 2 in x 2 in x 4 in
