connecting ductwork to diffusers
kgm2535
kgm2535
working through a MEP example for ductwork drawing and some diffusers directly below the duct aren't connecting
is there a command to make them join
attached is my drawing file
Victoria.Studley
Hi @kgm2535,
You may want to ensure the elevation isn't locked when you're adding duct:
  • Enter the DUCTADD command and open the Properties palette.
  • Under the Placement section, make sure the lock icon next to Elevation is set to unlocked.
You may also want to define a routing preference for your ducts, as most (if not all) of them appear to be Undefined.
If one or more of these posts helped answer your question, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Victoria.Studley
Hi @kgm2535,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided last week work for you?
If so, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
