Can't install from Deployment image
I have created a deployment image for MEP 2013from the Building Design suite 2013. However, when I try to install onto the client machines, it gets so far, then starts to "roll back" everything and then quits. I have tried several variations on the deployment but none seem to have any effect, and the same thing happens. We already have architecture 2013 installed - would this have any effect (have tried deployments both including and excluding architecture)?
DarrenP
what does the install log say?
there should have been one created when you created the deployment
DarrenP
2013/1/4:14:30:56 Steve.Mathewson WELLWOODPC02 === Setup started on WELLWOODPC02 by Steve.Mathewson === 2013/1/4:14:30:56 Steve.Mathewson WELLWOODPC02 Launch 2013/1/4:14:31:39 Steve.Mathewson WELLWOODPC02 === Setup ended ===
2013/1/4:14:31:07 Steve.Mathewson WELLWOODPC02 === Setup started on WELLWOODPC02 by Steve.Mathewson === 2013/1/4:14:31:07 Steve.Mathewson WELLWOODPC02 Launch 2013/1/4:14:31:40 Steve.Mathewson WELLWOODPC02 Installing DirectX Runtime: \\SBSSERVER\xxxxApplications\MEP2103\AdminImage\3rdParty\DirectX\DXSETUP.exe /silent 2013/1/4:14:34:11 Steve.Mathewson WELLWOODPC02 Install DirectX Runtime Succeeded  2013/1/4:14:34:11 Steve.Mathewson WELLWOODPC02 Installing AutoCAD® MEP:  TRANSFORMS="\\SxxxR\xxxx Applications\MEP2103\AdminImage\x64\en-us\MEP\MEP.mst;\\SxxxR\Terastation\share\0004_Software Applications\MEP2103\AdminImage\x64\MEP\MEP-mep2013.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="\\SBSSERVER\xxxx  Applications\MEP2103\AdminImage\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/4:14:37:14 Steve.Mathewson WELLWOODPC02 Install AutoCAD® MEP Failed Installation aborted, Result=1603 2013/1/4:14:37:14 Steve.Mathewson WELLWOODPC02 Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2013/1/4:14:37:16 Steve.Mathewson WELLWOODPC02 === Setup ended ===
(server details altered)
emily.xu
Autodesk Support
Autodesk Support
The installation failed at MEP installation with 1603 error. Can you check if this solution works?
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
