I am working on a project that requires a high level of detail. I have sanitary pipe networks in Civil 3d and would like to show wye fittings and other fittings. Is it possible to bring civil 3d pipe networks into Autocad MEP to add that level of detail?
If the fittings and the pipe system don't already exist in Civil 3D, then you will most likely have to redraw everything in MEP. If you are redrawing everything, then you might be better off just pulling in the centerlines of the pipe network for routing and location and then fill with MEP content.
Make sure upfront that MEP meets the needed level of detail to produce the desired "eye candy" so you don't have to spend time modifying content.
Hi Adam,
Thank you for submitting your question in our discussion forums. To follow up on Beka's suggestion, this is a great video showing you how to navigate Infrastruction Parts Editor and Inventor
Let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Great content @lim.wendy! Thanks 🙂
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Your question got successfully answered? Then just click on the 'Mark as solution'
Joaquim Moral
Spanish Community
