Appload in 2004
This widget could not be displayed.
Appload in 2004
What happened to my Appload? When I type it in I get "unknown command". I
eve tried going to the pull down and slect "load application", same result.
Anyone seen this problem. I guess I can work around it with editing the Main
lisp file.
Hi
If could be that the appload application isn't loaded.
Try loading appload.arx with the 'arx' command.
Lars-Ake Johansson
"Nick Fuller @ BFA" wrote in message
news:062E65BF38768373ED4BA2E898E51633@in.WebX.maYIadrTaRb...
result.
Main
> lisp file.
Its usually because 'demand loading' is disabled, set it to command invoke
and Object detect, in options.
result.
Main
> lisp file.
devashreekapse9897
Community Visitor
Community Visitor
The appload command is still not working i have used both ways as suggested above please help me with the same
pendean
Community Legend
Community Legend
@devashreekapse9897 You are replying to a post from the year 2003: are you really still using AutoCAD2004 too?
or are you using AutoCADLT by chance?
or would this be the solution you seek https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/appload-not-loading/m-p/8401725#M377...
