We are using 2017 AutoCAD Mep. The piping has all been drawn in 3d with insulation added. When we open the file in Navis works 2017, it will only show single line piping. We opened the drawing both ways, nwc out and straight open in navis. Same results both times.
Any help would be appreciated.
Solved by Keith.Brown. Go to Solution.
Check this post out. This is likely the culprit.
https://forums.autodesk.com/t5/autocad-mep-forum/pipe-comes-in-single-line-in-navis/td-p/3778446
