Vault Data Standard (2024) initial save issue
jpbrown16001
jpbrown16001
I am having an issue with Mechanical 2024 where after initially loading the software, when I start a new drawing, and then save for the first time the Vault Data Standard dialog does not pop-up and it saves as if it is not enabled.
I go to the Data Standard tab and it shows as enabled.
If I disable it, and then select enable, then when I save the dialog will pop-up.
I have attempted many different way to see if it was the template I was using, or if reloading the menu/CUI would correct it. Nothing seems to work.
The only thing that works is to create the new file disable data standard, enable data standard, save file.
After this, every consecutive file created from a new template, or no template, will save using the data standard dialog until AutoCAD Mechanical is closed and then the issue resumes when a new application instance of AutoCAD Mechanical is started.
It is not happening in AutoCAD (vanilla) installed on the same PC.
However, it does occur on other PCs with other user's AutoCAD Mechanical 2024 applications
Chancellor.Kurre
I am able to replicate this by not logging into Vault when I open ACADM. Once I log into Vault I get the data standard dialog as expected. Does Vault login state change anything for you?
