Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
UNDO for AutoCad Mechanical, plz explain how to use as single command
Hunteil
Hunteil
Hello, user of AutoCAD since 2000... daily user. We just updated to AutoCAD Mechanical. And now when I use the undo button or crtl+z, it undoes everything up to the last time I saved! This is horrible! I've had to redraw many things now and I'm fed up. Please help me... I can't seem to find a setting anywhere to put it to single commands.
I also noticed there's a pull down next to the undo button and it says: "Group of commands" and other says "undo 1 command".
It won't let me select the undo 1 command...it just says cancel over top it... What am I missing? I thought AutoCAD Mechanical was the same thing as the core product. I didn't expect them to change one of the most important tools!
Inventor: Model States is not a replacement for iParts / iAssemblies. It does not have all the same features yet and does not communicate well with our large currently in use libraries. 😞 https://forums.autodesk.com/t5/inventor-ideas/model-state-support-tabulated-parts-list/idc-p/11360616
pendean
Community Legend
Community Legend
What function were you trying to undo? Not everything is easy to undo in a single step.
>>>...user of AutoCAD since 2000... daily user...<<<
If I may ask, why are you not saving more often then? You should never be more that a few minutes from recovery ever.
FWIW a QSAVE sets an UNDO>Mark which can also be triggered manually by you as an abbreviation with lisp before you dive into a complex workflow. Explore UNDO in HELP for more details about all it can do, pulldowns on the Ribbon don;t tell the whole story.
HTH
Hunteil
Solution:
Type Undo (enter)
Type 1 (enter)
Type C (enter)
Type All (enter)
Options > User Preferences > Undo/Redo
Uncheck Combine zoom and pan commands
Uncheck Combine layer property change
