My title block for the first page of my sheets is the "source" block for the fields on the subsequent sheets. The issue is the source block looks slightly different than the field populated blocks on the following sheets. A simple solution is just making all of the actual sheets be the field populated ones, and have the original be a non-printed sheet that is just used for populating the job sheets. I'm just curious if there's a way to make the OG block look the same as the others. Looking at the settings they should look the same, but they don't. I have attached images to show the differences.
