AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Start Mode is read-only
12 REPLIES 12
Message 1 of 13
3462 Views, 12 Replies
Trying to get my start tab back and it says to change start mode value to 1 instead of 0. However my start mode is set to read-only and neither myself or our AutoCAD guru can figure out how to fix that.
12 REPLIES 12
Message 2 of 13
gaurav.satalkar
You will have to make this change in your registry: Change the value to 1.
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R21.0\ACAD-0005\Variables\*DISPLAYSTARTTAB
Follow this AKN article:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Hope this solves your problem.
Please ACCEPT AS SOLUTON if this works
Thank You,
Gaurav Satalkar
QA Engineer
Message 3 of 13
in reply to: gaurav.satalkar
That is the first thing I did however it did not resolve the issue. Also I only have R22.0 not R21.0, not sure if that makes a difference.
Message 4 of 13
gaurav.satalkar
Then you need to make the change under R22. Also set the Startmode, after changing the registry key.
You can try that and restart your product.
Hope this works.
Thank you
Gaurav Satalkar
QA Engineer
Message 5 of 13
Had to restart my machine but it worked! Thank you much.
Message 6 of 13
CNinBC
Hi @gaurav.satalkar ,
we are having this issue on our C3D 2019, the start-up page won't load, and the "StartMode" is set to "0" and readonly. Even if I change that to "1" in the registry, reboot computer, and relaunch C3D, it will revert it back to "0". any suggestion?
Thanks.
Message 7 of 13
in reply to: CNinBC
Make sure you are making this change from 0 to 1 in the HKEY registry (on your machine) AND in the command line (in autocad) type in STARTMODE and make the change there as well. Then power off and back on.
Message 8 of 13
in reply to: CNinBC
Sorry, forgot to clarify getting to HKEY_LOCAL_MACHINE go to start bar and type in regedit.
Message 9 of 13
CNinBC
Thanks @Anonymous  for your reply, however, I don't think that is going to work.
first, I changed "StartMode" from 0 to 1 in Registry, but as soon as I re-launch C3D 2019, that key will revert back to 0,
and there is no way in C3D to set "StartMode" to "1" as it's read-only, as you can see on that image.
Message 10 of 13
CNinBC
is that key under local_machine?
I changed the one under "Computer\HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R23.0\ACAD-2000:409\Profiles\PROFILENAME\Variables"
Message 11 of 13
in reply to: CNinBC
My exact path:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R22.0\ACAD-1005\Variables\*DISPLAYSTARTTAB
Set (default) to 1
Message 12 of 13
CNinBC
thanks @Anonymous , the issue has been resolved, the registry does allow the "StartMode" to be writeable.
the issue was caused by the deployment package, IT didn't select the "Display start tab" when they created the deployment, mine was the first test machine and installed manually.
Message 13 of 13
and where is that in autocad for mac? :slightly_smiling_face:
