Announcements
We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
selecting between stacked lines
bmotley
bmotley
If you have two lines stacked that are of different line types, say hidden and center, there will be areas that you can see one line or the otherr or even have some aeas of no line which would be in between areas of the dashed lines.  In my 2018 I could select either line depending where my cursor was on the line or even cut through and miss both lines if I drew a window through the "gap".  Now that I am in 2019, I cannot select the line on the bottom or cut through the gap with a window.  Is there some setting or variable that dictates selecting in this scenario?  We have others in the office who can do this in 2019, but I cannot.
Thansk.
illusionistNUGXG
This behaviour can be changed with the variable LTGAPSELECTION.
0 = gaps are ignored
1 = gaps are used in the selection
This was new implemented in AutoCAD 2018.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @bmotley,
I am checking in to see if the great post by @illusionistNUGXG helped with your issue.
Please add a post letting the community know.
If a post was helpful, Likes are always welcome.
Please Accept As Solution any post(s) that answer your question or solve the problem.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @bmotley,
I wanted to follow up with this article which also explains how to cycle through overlapping lines in AutoCAD
All the best,
Cheryl Buck
bmotley
Thanks for the help.  This fixed my issue.  Much appreciated.
