08:36 AM
I am currently using AutoCAD Mechanical 2018 and when I use the dimension radius command an arc appears at the end of the leader. The leader points to the arc and not the radius. Is there a way to turn off the arc symbol at the end of leader when using this command? I did a quick look thru the leader properties but did not see anything (I definitely could have missed it tho.).
Thank you in advance for your help.
[The subject line of this post has been edited for clarity by cheryl.buck from: Removing Radius Leader Arc]
Link copied
