AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Removing Radius Leader Arc extension in AutoCAD Mechanical
3 REPLIES 3
6928 Views, 3 Replies
I am currently using AutoCAD Mechanical 2018 and when I use the dimension radius command an arc appears at the end of the leader. The leader points to the arc and not the radius. Is there a way to turn off the arc symbol at the end of leader when using this command? I did a quick look thru the leader properties but did not see anything (I definitely could have missed it tho.).
Thank you in advance for your help.
[The subject line of this post has been edited for clarity by cheryl.buck from: Removing Radius Leader Arc]
3 REPLIES 3
cheryl.buck
Hi @Anonymous,
It sounds like you are wanting to remove the Radius Dimension Extension. For individual dimensions, this can be done in the Properties Palette by changing the Ext line value to OFF under Lines & Arrows, see the before and after screen shots below:
Please let me know if this helps.
Power Dimensions do work differently from standard AutoCAD dimensions. This AKN article and associated article links often help.
About Power Dimensions (AutoCAD Mechanical Toolset)
All the best,
If a post was helpful, Likes are always welcome.
Please Accept As Solution any post(s) that answer your question or solve the problem.
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
in reply to: cheryl.buck
Cheryl,
Thank you for the suggestion. I dug around a bit more and found what I was looking for here:
[This post has been edited for clarity by cheryl.buck]
cheryl.buck
Hi @Anonymous,
That is wonderful news! Thanks for posting to let the community know you were able to resolve the issue, and how.
All the best,
Cheryl Buck
