The menu bar is gone. I don't know how to get it back. I don't know what I did but it's completely vanished
[The subject line of this post has been edited for clarity by cheryl.buck: Menu bar gone to Quick Access Toolbar is gone]
Solved by Sridhar-Autodesk. Go to Solution.
Hi @thefrits95,
I see that you are visiting as a new member to the AutoCAD Mechanical forum. Welcome to the Autodesk Community!
The menu bar can be displayed again by typing MENUBAR in the command line and changing the value from to 1. It can also be accessed from the quick launch drop down. See the Autodesk Knowledge Network (AKN) article below:
All the best.
Hello @thefrits95,
I am checking back to see if my post helped you with your problem.
All the best.
thank you for replying. unfortunately no, The quick access tool bar is gone. I think I miss worded what i wanted to say orginally.
Please see below thread to add QAT back to Ribbon
https://forums.autodesk.com/t5/autocad-forum/quick-access-toolbar-missing/td-p/2591992
Hi @thefrits95,
Thanks for the correction, the suggestion that @Sridhar-Autodesk provided in his post has worked a couple times for me. Hope it works for you!
All the best,
Please select the Accept as Solution button if @Sridhar-Autodesk's post solves your issue or answers your question
[This post has been edited for clarity by cheryl.buck]
