QTY Not Updating In BOM
Message 1 of 22
Hi All,
I'm having an issue with the BOM QTY not updating after copying a block on the same drawing.  When filling out the Properties there is an option to under Management to connect other blocks that are the same, which then updates the QTY in the BOM.  But after filling out the block properties and adding the balloon I want to copy that same block again, but for some reason it's not updating the QTY and wondering how to connect it to the original block so the QTY updates in the BOM?
john.vellek has embedded your image(s) for clarity
Replies (21)
Message 2 of 22
john.vellek
Hi @Anonymous,
Is this AutoCAD Mechanical or something else? It doesn't look like core AutoCAD.
John Vellek
Message 3 of 22
Hi John,
I'm using AutoCAD Mechanical 2014 but I've also got the standard core AutoCAD as well if the QTY in the BOM could be done with that.
Regards
Graham Coutts
Message 4 of 22
john.vellek
Hi @Anonymous,
I don't work in Mechanical and the BOM is part of that application as opposed to core AutoCAD. If you want to share a sample file however, I am happy to take a look to see if I can help.
John Vellek
Message 5 of 22
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I have seen something similar occur when a block or content library object is duplicated using Copy/Paste. I believe it usually has to do with multiple instances of attributes and constraints.  How are you duplicating the block?
If you would like me to take a look at the block, I would be happy to do so. Please use the ETRANSMIT command and include any Xrefs or other associated files.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 6 of 22
What I'm doing is using copy/paste but I've tried using AutoCAD Entities under special paste and even trying to save as a different file and adding it to my original file in a similar way to Inventor but nothing works and not sure what I'm actually doing wrong to get the Qty to increase.
I've attached a snapshot of the issue and also an AutoCAD file but the component is a block and doesn't have any Xref's attached to it as the component front was copied into Microsoft paint and then pasted using Special Past for paint then saved as a block.
Regards
Graham Coutts
[This post has been edited for clarity by cheryl.buck]
Message 7 of 22
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I apologize for the delay in getting back with you. Thank you for the file and the information, I will take a look and get back with you on what I find.
All the best,
Cheryl Buck
Message 8 of 22
Thanks Cheryl.
Message 9 of 22
VinodBalasubramanian
Autodesk Support
Autodesk Support
Hi There,
I had a look at the drawing and it seems your part reference was disconnected. Try to select the orange icon there, it should get you to have it activated. Then copy and paste your model, you should see quantity updating fine.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Message 10 of 22
I tried clicking on the orange icon in the BOM and nothing happens and the Qty still says 1.
Message 11 of 22
Autodesk Support
Autodesk Support
Hi Graham,
Once you click the orange icon, it should change into blue that means your part ref is active. Then try to copy your object in the drawing, it will change the quantity to the right value. Did you try testing it out with the drawing i sent to you ?
Message 12 of 22
The icon on the BOM table that I have are blue.  I couldn't use your drawing as I'm working with AutoCAD 2014 so if you could say save it in for 2014 then I'll try yours.
Regards
Graham
Message 13 of 22
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I have attached the file in AutoCAD Mechanical 2014 format. Please let us know if this helps.
All the best,
Cheryl Buck
Message 14 of 22
Thanks for sending the cad file in 2014.
Tried it and still no joy and even tried making a new template and the Qty will still not change when I click on the orange symbol in the snapshot.  Would it be down to the way I'm copying and pasting, as I'm using Ctrl C and Ctrl V and I've even tried using Copy from the Modify tab and using Paste from the Clipboard tab and selecting Paste and even Special Paste then AutoCAD Entities.
Is there any settings that I could also look at as well.
Regards
Graham
Message 15 of 22
Autodesk Support
Autodesk Support
Hi Graham,
It seems strange here. Please go to help - About AutoCAD Mechanical and take a screenshot and attach it to your reply. We will try the same build and see if we could reproduce it.
Did you have any custom CUI loaded with your Mechanical ?
Message 16 of 22
Didn't change any CUI settings at all and all I've done is saved a Inventor template to DWG file to use in AutoCAD and wouldn't thought that would make a difference.
Is there something in the CUI that I could try?
Regards
Graham
Message 17 of 22
john.vellek
Hi @Anonymous,
I am sorry that this thread is still on-going and does not yet have resolution for you.  Please allow me to start this from the beginning so i have a clear idea of what you are experiencing in this process.
Please tell me the exact steps of your process and with which applications you use in each step.
Please also make a Screencast that demonstrates your steps.
I am also curious about the exact version of your applications and the operating system you have installed.  If you have 32-bit involved, then the model documentation from the Inventor model will likely not function properly.
John Vellek
Message 18 of 22
Sridhar-Autodesk
Hello @Anonymous,
I think the second block was inserted before part reference definition was created.
Please try below steps and let us know if this helps;
1. Command: copyclip>>Select the second block
2. Open a new drawing
3. Pasteclip and insert the block anywhere in the screen
4. command: ampartref>>Block option and select the Block
5. Rename the block if required, in the Part Reference dialog box and click OK
6. copy this block to verify if the quantity is updated.
Sridhar Subramani
Senior Product Owner
Message 19 of 22
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am checking back to see if the suggestions provided in the thread helped with your issue. Please post an update letting us know the results.
All the best,
Cheryl Buck
Message 20 of 22
Hi All,
Sorry for the late reply.
Starting to slowly get to the bottom of the issue with the BOM Qty not updating and noticed when the Name in the BOM has a U value it won't update the Qty when copying and pasting the same block, but if the name from the properties does go over to the BOM, the Qty will update when copying and pasting the same block.  So sometimes the Name I've given the block doesn't always go over to the BOM but in the properties it reads as it should.  Item 1 in the BOM screenshot it shows U48 but in the Properties screenshot under Misc it says the block name.
So how can I change the U value in the Name of the block in the BOM and not just overriding it as this doesn't work?
Regards
Graham
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
W
Akamai mPulse
W
Digital River
W
Dynatrace
W
Khoros
W
Launch Darkly
W
New Relic
W
Salesforce Live Agent
W
Wistia
W
Tealium
W
Upsellit
W
CJ Affiliates
W
Commission Factory
W
W
Typepad Stats
W
Geo Targetly
W
SpeedCurve
W
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
W
ClickTale
W
OneSignal
W
Optimizely
W
Amplitude
W
Snowplow
W
UserVoice
W
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
W
W
AdWords
W
Marketo
W
Doubleclick
W
HubSpot
W
Twitter
W
Facebook
W
LinkedIn
W
Yahoo! Japan
W
Naver
W
Quantcast
W
Call Tracking
W
Wunderkind
W
ADC Media
W
AgrantSEM
W
Bidtellect
W
Bing
W
G2Crowd
W
NMPI Display
W
VK
W
Adobe Target
W
W
Trendkite
W
Hotjar
W
6 Sense
W
Terminus
W
StackAdapt
W
The Trade Desk
W
RollWorks
W
Your experience. Your choice.
