AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
PROBLEM COPY / PASTE STRUCTURES
4 REPLIES 4
coloretti74davide
279 Views, 4 Replies
Good morning,
I have a problem with the STRUCTURES of Autocad Mechanical 2019.
Since yesterday (perhaps due to a combination of keys clicked at random ... I don't even know) I can no longer do Ctrl + C / Ctrl + V on the structures.
I am able to copy, but the result is no longer Structures, but loose "lines".
This is done either by doing it on the current Drawing or by copying / pasting from one Drawing to another.
It only works using the COPY command, but this is only possible on the current Drawing.
Basically Ctrl + C / Ctrl + V no longer does its job.
I tried them all, even on the net I can't find any posts about this problem?
Anyone have an idea?
Thank you
Davide
4 REPLIES 4
Hi
You can accomplish this using two ways;
1. For copy/paste, window selection will not work.  You need to select each structure object, cycle through the selection (keeping clicking until you see structure component name) and then use CRTL +C to copy.
Switch to a new drawing, enable "Mechanical structure" on the status bar by clicking the "Mechanical structure" button.  Use CRTL +v to paste the structure component.
2. Use AMSCATALOG and browse to the external file>>Right click on the component view and "Insert as Xref"
In the Mechanical Browser>>Right click the component and select "Localize"
Hope this helps.
Sridhar Subramani
Senior Product Owner
Grazie per il tuo aiuto, ma non risolve il mio problema.
Punto 1 Lo faccio sempre, ma il problema persiste.
Non ho capito il punto 2, se digito AMSCATALOG non succede nulla
Hi
Please see the screencast video for both options;
https://autode.sk/3KcSg8L
Sridhar Subramani
Hi, thank you for your cooperation.
But I know these functions well, I normally do what you recommend,
but my problem persists!
