Path Array Question
Path Array Question
jpionk
Message 1 of 1
Path Array Question
jpionk
Hello, this is my first post here. My company is moving over to AutoCAD software and I am learning the ropes. This piece is on a large radius, it's not a flat line and I am using path array to add these bumps using the 1st bump as my reference and the arc that it lies on as the path (offset brown arc shown above). I am trying to see if there is a way to retain the gap you see on the first bump, throughout the array, without having to explode and trim away every little piece . The attachment probably explains my goal better than I can.
Thanks, I look forward to hearing your suggestions!
-Josh
Replies (0)
