we are not able to modify Autodesk mechanical desktop drawings in AutoCAD mechanical 2005/ 2013. I am getting error "You can not edit Autodesk Mechanical drawings in in AutoCAD mechanical". It seems our old drawings are created in Autodesk mechanical desktop. I tried to save as different format but tool is not allowing to do so. Can you please guide me how to update and modify drawings in AutoCAD Mechanical 2005 or 2013.
[The subject line of this post has been edited for clarity by cheryl.buck from: How to modify Autodesk mechanical desktop dwg in AutoCAD mechanical 2005/ 2013 ]
Solved by VinodBalasubramanian. Go to Solution.
Solved by cheryl.buck. Go to Solution.
Hi @piyush.gangwal,
I am sorry you encountered this issue. The following Autodesk Knowledge Network (AKN) article explains how to convert MDT files:
Please let me know if this works for you, or if you have any questions.
All the best,
If my post was helpful, Kudos are always welcome.
And if it answered your question or solved your problem, please select the Accept as Solution button.
Hi @piyush.gangwal,
I am checking back to see if my post helped you with your problem.
All the best,
Hi Stephen,
We have removed that article as its no longer supported workflow. Please take a look at this one. Using Inventor option is the most accurate and recommended approach here,
i had the same question regarding opening an Mechanical desktop files to autocad, i have old mechanical desktop files in 3D, to create 2D drawing pages in the same file, i am able to open mechanical desktop files, open 2D layouts in autocad but i can not export the 2D drawings in DXF or 2D autocad formats, i just need from my old Mechanical desktop files to export the 2D pages in DXFs, the previous autodesk knowledge link does not work,
Thank you
Hi @benboubaker,
Thank you for posting. The Mechanical Desktop (MDT) file format is not supported in AutoCAD Mechanical, the Inventor workflow mentioned in the post by @VinodBalasubramanian above, is the recommended one.
There may be a third party product that can convert your MDT format files to a format that is supported in AutoCAD products, see the following list:
What files can AutoCAD import?
All the best,
