Multiple lines using LINE command
When using the line command and typing in a dimension for the line, there will be two lines, one is the correct dimension and there will be a  line on top of the dimensioned line and is just a random length line that is then deleted to leave the correct line. Ran a repair, did not fix issue. Not good on explaining the issue...but basically getting two lines using the line command instead of just one.
Re-installed Autocad......fixed issue..
Jon.Dean
Glad you fixed your line problem, was a bit drastic; re-installing.
You could have just "Reset Settings to Default" from the Start Menu.
Jon.
Jon Dean
What all does that reseet Jon?
Jon.Dean
It resets AutoCAD to how it was when you first installed the product.
Just a quicker method than having to re-install.
Jon.
Jon Dean
Ok, thanks for the tip.
