Move object along line
i want to move one object from one point to another along particular line. For example, if i want to move by 1500mm, i will first put one x-line at that point with perpendicular to center line and then offset 1500mm. Then move the object to that point. Second method i am using is putting one circle with radius of 1500mm and move the object to the intersection point of circle and center line. My query is without doing this offset, if i able to set the angle by selecting two points on that center line, it will be easy for me by putting 1500mm and move the object. i checked if it is possible by enable polar tracking and temporary track point snap. But, i unable to find a solution. Please see the attached screen shot.
Kindly give any idea.
Suresh
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for posting your question. I apologize, I am not sure I understand completely, but would be happy to take a look at what might be possible if you would like to post a ScreenCast of the steps you are taking, and a sample file.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
