AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
How to prevent double clicking outside a viewport to exit it from invoking AMPOWEREDIT on a block in model space?
1 REPLY 1
Christopher.Verderame
327 Views, 1 Reply
My company just switched from Vanilla to Mechanical and we are experiencing an issue with AMPOWEREDIT. What happens is we double-click on empty paper space to exit a viewport, but there is a block/x-ref in model space outside of what is shown in the viewport. Even though the block/x-ref is not visible and I am clicking on empty paper space, it will invoke the AMPOWEREDIT which calls the REFEDIT command to edit the block/x-ref. (see pic)
This is very annoying as some of our blocks/x-refs are very large files and it can take 30+ seconds to open the REFEDIT dialog box just to hit Cancel. This really interrupts our workflow.
Is there any way to fix this?
1 REPLY 1
We figured out that if you hold the control key down while double clicking, it will prevent calling AMPOWEREDIT and it will exit the viewport
