how to convert dwg file into solid step file?
Hello everyone,
I converted my dwg file into step file by using stepout command. But it gets converted into surface structure.
I need this dwg file to be solid step file.
Please suggest me a  way to do this.
pendean
Community Legend
Community Legend
This maybe an obvious question, but are you trying to export an AutoCAD 3DSOLID or something else?
STEPOUT does not convert other objects types to solids.
I have revit solid files. I exported these files into dwg files and then using autocad mechanical, I am trying to convert these into step files.
the stp files are surface files. is there a way to export them as solid files?
