Gettting Copyclip when pressing F8
Anders_KE
Anders_KE
Hi I have just Installed AutoCAD mechanical 2018 on a brand new computer with windows 10 64..
Now when I'm pressing F8 the command line shows copyclip and if I press it again it show Ortho on / off. But the first time I press F8 it exits the command and show Copyclip in command select objects.
The Keyboard is a Danish std 102 Keyboard no special function I the F-key row
Any one who now have to solve this situation?
gaurav.satalkar
Can you please check if this technical solution solves your problem?
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/F8-fun...
Also, there is a similar problem faced by another user, and it got solved by toggling the F Lock key. Please try restarting your ACM as well.
https://forums.autodesk.com/t5/autocad-forum/ortho-and-osnap-not-working-correctly-f3-and-f8-got-mix...
Hope this helps.
Please "Accept Solution" if this solves your problem.
Gaurav Satalkar
QA Engineer
Anders_KE
No neather of this solved it. On one of the locations where I point to there was some old shortcuts to Autocad Mechanical 2015 add something plot styles I jyst deleted those and then it have worked since
Regards
Anders P.
Anders_KE
Sorry to tell you but Neather of the suggested solutions was the reason. The Reason was a 3rd party software called UNO SOFT our phone system I had to reset it's short cuts back to default then it worked!
sven.olssonHFEMT
Community Visitor
Community Visitor
Same issue here...thank you for getting me in the right direction!
M.Monterd
Community Visitor
Community Visitor
Thank you for writing this answer!! I had the same problem and the culprit was also a Phone System that was installed!
