AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Fraction to decimal question
3 REPLIES 3
7223 Views, 3 Replies
I know this is an elementary question, but I have completely forgotten how to do it.
I have a drawing from our customer that is dimensioned in fractions.I am needing to change these do decimal dimensions  for the guys on our shop floor to check to.
How do I do this?
Thank you very much for your help.
How do I do this?
3 REPLIES 3
Didn't figure this would be so hard to get an answer to,
but I sure appreciate all the help I got.
nestly2
nestly2
I don't know Mechanical, but in AutoCAD.    Dimstyle > Modify > Primary Units > Decimal
"D" at the command line should launch the "Dimstyle manager"
Steve_Bessette
Steve_Bessette
Autodesk Support
Autodesk Support
Since you are using AutoCAD Mechanical, you can change the dimension style from the current state to the AM_ANSI style.  This will change the fractional dimension to a decimal.  You can make this change via the Properties Palette.   However if you choose to keep the same dimension style, you can change the "Primary Units" of the dimension string from Architectural to Decimal.  To to this you will want to click the dimension line, within the ribbon the Power Dimensioning tab will appear, and click the arrow next to "Dim Text".  Here you will see the option to change the primary units.
The link below is for a video that will show both procedures mentioned above.
http://screencast.com/t/4pZm2hdn1
If this resolves your inquiry, please check "Accept as Solution".
Steve Bessette
Support Specialist
Product Support
Steve Bessette
Support Specialist
Product Support
