Announcements
Fillet Help Please
ngoquangnhut.1995
Observer
Fillet Help Please
ngoquangnhut.1995
Observer
Observer
I've been trying to fillet 4 corners of a solid box. But I was able to fillet 3 of them, and the last one said that I couldn't bend the edge. Please see the pictures and the attached file below. Thank you.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @ngoquangnhut.1995,
Welcome to the AutoCAD Mechanical Forums Community!
Thank you for sharing the image as well as the file that helped understand the issue better.
It looks like there is only the vertical edge to fillet on that corner, I suspect the warning is because it and the lower edge have already been partially filleted.
Fillets for this shape work best when the vertical edges are filleted separate from the continuous line below them. This may work better for you:
  2. Start a new FILLET command.
  3. In the command line, select Multiple.
  4. Select one edge.
  5. Enter the Radius.
  6. In the command line select Chain.
  7. Select another of the lines around the bottom edge, a continuous line around will be highlighted.
  8. Press Enter.
Let me know if this helps.
All the best,
[This post has been edited for clarity by cheryl.buck]
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Type a product name
