Exporting a BOM to Excel
Is there a way to export a Bill Of Materials (BOM) to Excel? The reason that I ask is that our engineering services people need to put the parts in SAP, but don't have AutoCAD. They can however open the Excel file and copy and paste it into SAP. Any help would be great! Also if I need software free would be great too!
Sridhar-Autodesk
Follow below steps to export BOM to an Excel sheet from AutoCAD Mechanical.
1. Command AMBOM
2. In the BOM dialog box-->Click export button as shown in the attached image
3. In the File of Type dropdown, select Microsoft Excel
4. Specify a name and save the file to a location.
Sridhar
Software QA Engineer
Manufacturing Solutions Division
Autodesk, Inc.
Sridhar Subramani
Senior Product Owner
Thank you so much!
That would be sweet and easy, but my version "2015" does not have excel as an option.  I have a report generator that has only three options .txt, .csv, and html.  Am I looking in the wrong place for the new version?
Help me if you can Obi wan. 🙂
I figured it out. I saved it in .csv format, and I was able to open in in Excel. This is usually how it goes, I ask a question, then figure it out about an hour later. FYI - when opening the file with Excel, make sure you look for ALL file types in the drop down list, that was my mistake.
ruddra.singh
Observer
Observer
To export a table from AutoCAD and edit it in Microsoft Excel simply select the table, then right click and choose “Export”. The table will be exported in .CSV file format.
Next, right click on the exported .CSV file and from the options menu choose Open with Excel.
VIOLA!
