Export As Step File
Export As Step File
Export As Step File
Trying To Export Dwg Files As Stp Files. Mechanical Makes Stp File, But It Shrinks It To An Odd Scale. How Can I Get It To Export At 1:1 Scale
Jason.Rugg
@AnonymousDo you have your drawing units setup correctly?
Tried To Find Settings For Scaling Units. Can't Seem To Find The Correct Location To Make Changes.
Just Starting To Use To Assess Use In Company.
inchul.lee
Autodesk Support
Autodesk Support
Hi @Anonymous ,
You can specify the units in Drawing Units dialog box (UNITS command):
And in an application to open the STEP file, you can also specify import units. Below screenshot shows Inventor as an example:
You may want to share your file for review.
Inchul Lee
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous
I see that you are visiting as a new member to the AutoCAD Mechanical forum. Welcome to the Autodesk Community!
I am checking back to see if the information provided by @inchul.lee helped resolve the issue or answered your question. Please post an update letting the community know.
Additionally, the command DWGUnits lets you configure advanced unit settings. This is a command line based dialog.
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
