Error: "You cannot edit Autodesk Mechanical Desktop drawings..."
Dear all I´m triyng to edit a 3D object that was created by Mechanical Desktop 5 in a new version (Mechanical 2019). When I try to save the file, all commands blocks it self authomatically and the error "You cannot edit Autodesk Mechanical Desktop drawing in Autocad Mechanical, All AutoCad Mechanical commands including SAVE are now disable". Please, see the attach enclosed Thanks in advance for your help
[The subject line of this post has been edited for clarity by cheryl.buck from: Autodesk Mechanical 3D 2019 has all commands disable when you try to save filesMechanical.PNG
Accepted solutions (3)
DarrenP
looks like you have to go through vanilla Autocad first: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-c...
DarrenP
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
This error usually occurs when saving a file that was originally created in Autodesk Mechanical Desktop (MDT) in AutoCAD Mechanical.  The article provided by @DarrenP explains the issue and offers a solution.
Please post and let the community know if this worked for you.
All the best,
If a post was helpful, Likes are always welcome.
Please select the big green Accept as Solution button on any post that answered your question or solved the problem.
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Following the links to the resolution, apparently to an article by @DarrenP , and I arrive at "Page Not Found".
Was the article deleted or did the article move?
SurachaiB
I have a problem seem this case.But I go to solution follow link (page not found).
Anyone have any solution?
pendean
Community Legend
Community Legend
