Dimensioning between different objects across viewports
The pictures below show four different blocks, made by someone else, that I've copy/pasted into the model space. The last figure shows me trying to get the actual distance between to points in two different blocks across two viewports. After reading several posts on how to trick AutoCAD into not displaying the paper space distance, I found one that describes replacing the dimension with an expression that renders the desired result. The only problem is that I don't know how and where to create an object property containing the dimension expression that will show up in the list. I realize that the issue has been thoroughly debated over the course of the last 15 years or so, but didn't find anyting that is helping me so far.
Any ideas anyone?
Block mada by someone else
