Hi @tylers7G9HY,
I had a chance to run some more tests and have reached out to my team for clarification. I did observe that dimensions in layout space are placed appear to be placed on the primary XY plane (usually Z=0), however, the nodes for the dimension are placed on the chosen geometry which may be above or below the XY plane (see screen shot below).
When rotating the text position by its node, the arrows appear to disconnect, I suspect this is because it is rotating on a 3 dimensional circle. I understand AMPOWERDIMs treats 3 dimensional objects in layout space as flat, so it places all dimensions and their respective nodes on the primary plane of the 3D object selected rather than the geometry selected.
For best results, the AMPOWERDIM command will associate appropriately for your view. For a circular shape like this, choose Radius then Diameter and you should no longer have issues with your dimensions becoming disconnected.
Please let me know if you have any questions.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider
Liking the post.
