Announcements
Custom settings import on new install
yafet_zeraiFY84S
yafet_zeraiFY84S
Just started a new job and would like to use custom settings that my colleagues use. I have tried to import those but i get an error message (those settings are exported from another coworker). Is there a soulution for this?
Keshava_Murthy
Hi @yafet_zeraiFY84S,
Please post the complete error message or the screenshot of the error message for finding a solution.
Do check if the below method works for you.
From your colleague's machine.
Launch the product and go to options > Profiles > create a new profile say, "custom profile" by clicking on Add to list > Select the custom profile and click on "Set Current"
Now export this profile and copy that file to your machine and import it, using the import in Options.
Please click ACCEPT SOLUTION if my post helps in solving your issue or answering your question.
Keshava Murthy
AutoCAD Mechanical Team
pendean
Community Legend
Community Legend
You both need to be using the same exact 100% identical year version of AutoCADMECHANICAL too, are you?
yafet_zeraiFY84S
Thanks, I did the import thing and in options->profile I could change to the new one and it worked!
yafet_zeraiFY84S
Yes, we are using the same version.
Keshava_Murthy
@yafet_zeraiFY84S
I'm glad it helped 🙂
Keshava Murthy
